Author Topic: resistive load  (Read 2262 times)
Coxy
resistive load
« on: June 20, 2017, 08:33:19 PM »
Hi, need a little help.  I have a Gurd controller and have on hand 8 X 1ohm 100watt cheap metal clad resistore I wish to use for now.  Staying within the limits of this controller using the two fets what would be my best setup.
THX Coxy
Coxy
Re: resistive load
« Reply #1 on: June 20, 2017, 10:45:49 PM »
Forgot to mention it is for 12V
  • Moderator
Re: resistive load
« Reply #2 on: June 21, 2017, 06:55:06 PM »
Not the best choice of resistors. Personally I don't like that style.
Make 2 banks of 4 resistors in series, for 4 Ohm's total per bank.
That will be about 3.6 A per bank (52w total per bank).
Then use one mosfet per bank. And keep the heat sinks separate. No need for a heat sink, because 3.6A won't get the get hot.
Keep the MOSFETs tabs isolated from anything electrical.
Coxy
Re: resistive load
« Reply #3 on: June 21, 2017, 07:09:32 PM »
THX Gurd for your info.  I will get a better dump load for the second circuit that I got from you ;D
