Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Notices
Classifieds
---SOLD--- F&P Stator and magnet drum plus mount for a HAWT ---SOLD---
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ---SOLD--- F&P Stator and magnet drum plus mount for a HAWT ---SOLD--- (Read 5558 times)
Administrator
SuperHero Member
on:
August 19, 2017, 04:48:51 AM »
F&P stator and hub along with a Randy's Workshop mount for a horizontal wind turbine. The mount uses a Yaesu thrust bearing(can buy from ham radio stores like DX Engineering, Gigaparts etc. I can get you links to them) to mount to the mast and has a swivel mount for the tail to turn it out of the wind. I have to much going on plus I cannot do the tower work I used to so getting this up is not an option. My back is getting worse so time to thin the project herd and concentrate on stuff I can do on the ground.
Asking $140+ actual shipping from 56237. It is large and heavy so it will be ~$50 or more I am betting.
Not in the picture but I have a pulley mount I was going to modify to use as a mount for the blades. It will need shimming and set screws added plus a plate made to mount the blades to. I will include that also(was $15 new)
Last Edit: November 06, 2017, 04:29:54 PM by Bruce S
Logged
Administrator
SuperHero Member
Re: F&P Stator and magnet drum plus mount for a HAWT
Reply #1 on:
September 04, 2017, 03:08:59 PM »
$135 plus I have a 3 phase rectifier assembly for it.
Logged
Administrator
SuperHero Member
Reply #2 on:
September 15, 2017, 06:46:06 PM »
$125, I need this gone!
Logged
XeonPony
Global Moderator
Hero Member
Country:
Sanity is over rated!
Reply #3 on:
October 16, 2017, 02:22:51 PM »
How much for just the motor as I have every thing ells. and what is the stator wired for?
Logged
Administrator
SuperHero Member
Reply #4 on:
October 16, 2017, 07:00:31 PM »
Will only sell as a package deal, stator is stock wiring
Logged
Administrator
SuperHero Member
Reply #5 on:
October 18, 2017, 06:41:03 PM »
$100 want this gone!
Logged
XeonPony
Global Moderator
Hero Member
Country:
Reply #6 on:
October 27, 2017, 11:33:58 AM »
Bought n payed for! sorry folks I got this one
Will log results in the forum as it grows!
Logged
Administrator
SuperHero Member
Reply #7 on:
October 27, 2017, 06:19:19 PM »
Yup sold!!
Have fun, all you need are blades, the bearing, and a tower to mount it on! Well and a blade mount... I included one I thought about using but it needs shimming to fit tight
Logged
XeonPony
Global Moderator
Hero Member
Country:
Reply #8 on:
October 27, 2017, 09:59:06 PM »
well got a 22 foot tower to start, the bearing is at a scrap yard just need to pick it up along with two 9" disks at 1/2 thick of good steel! figured go with flange mounts on every thing 5 bolt pattern.
Can't wait!
Logged
Administrator
SuperHero Member
Reply #9 on:
October 28, 2017, 09:27:50 PM »
The mount is designed to use a Yaesu Ham Radio tower thrust bearing GS-050... bolt on and for a 2" mast... Don't know if any other flange bearing will have that same bolt pattern 2.645" across or 1.865" on a side in a square pattern...
Logged
XeonPony
Global Moderator
Hero Member
Country:
Reply #10 on:
October 28, 2017, 10:18:11 PM »
Nothing some cutting oil and a good array of drill bits won't fix! but I'll try and make the hub conform to the current lay out.
Logged
XeonPony
Global Moderator
Hero Member
Country:
Reply #11 on:
November 06, 2017, 01:42:23 PM »
Stator arrived safe and sound and is in my hands! Can't wait to get it all set up and running thanks for the extra bits! they will be handy!
Logged
Administrator
SuperHero Member
Re: ---SOLD--- F&P Stator and magnet drum plus mount for a HAWT ---SOLD---
Reply #12 on:
November 06, 2017, 06:51:07 PM »
Tossed in whatever I thought would be handy!
Logged
XeonPony
Global Moderator
Hero Member
Country:
Reply #13 on:
November 07, 2017, 07:08:37 PM »
Any links to the tail boom set up and adjustment?
Logged
Administrator
SuperHero Member
Reply #14 on:
November 08, 2017, 07:09:49 PM »
Not that I have found but it uses a similar offset design as the Other Power machines. Most use a 6' rotor diameter and from there you will have to calculate tail boom size and position... backshed may have info on it too...
Logged
Print
Pages: [
1
Go Up
« previous
next »
Notices
Classifieds
