Below is a drawing of the 2nd version, This also helped to increase torque but I think there are more possibilities yet to be explored.
The version I'm working on now will help direct as much of the air flow through the outer diameter and has a bit different wing design. Since the forces are basically wasted the closer to center you get by directing the air flow where it will do the most good.
I came up with a better way to imagine what was going on as the wind passed through a turbine. I was trying to think of a mass that would work like pudding, jello... I had to laugh then thought of a cheeze cutter. Its easier to imagine what would happen to the cheeze if pressed through a turbine, so if you imagine your turbine as a cheeze cutter, you can see what it will do to the cheeze as its pressed through the machine. After that a whole slew of ideas flooded my mind. So far its quite impressive.
Have Fun... more to come soon
Ed
Have FunHave Fun! Windstuff Ed
Looks really interesting. Would a 4' wide x 8' high unit do 400-500 watts at 18 mph?
If I'm following you correctly, increased diameter of this unit should be a good thing. Of course that will result in slower rpm, but not really a problem if a large diameter alternator is used. If the tip speed is up, then Re number will be too and it seems that venturi you have going will be more active... especially on the upwind side.
I'm really looking forward to your developments on this one - good luck and looks like you're already having fun!
Ted.[ Parent ]
Having fun Ed Have Fun! Windstuff Ed[ Parent ]
Have Fun Ed Have Fun! Windstuff Ed[ Parent ]
The largest stumbling block I faced wasn't in learning new ways of extracting power from the wind... it was the process of unlearning, then I could move forward more freely.
Have Fun EdHave Fun! Windstuff Ed[ Parent ]
this development is the most interesting machine I've seen on this website. I'm quite convinced that one day someone will make a VAWT, which is both simple and effective at the same time.
This machine by Ed... I'm waiting for some measurements concerning the power characteristics...
