With a project we had the problem that
the permanent magnet generator
needs a bit too high speed for the
prop to start charging batteries.
At normal low winds the prop is turning,
but the direct drive permanent magnet generator
is not charging because the
voltage is too low.
We installed there a transformer before the rectifier to double the
voltage. And also connected the generator parallel
to the transformer to go directly through a
rectifier to the batteries.
When measuring the currents, out of the transformer never comes more than 2 amperes,
because the transformer steel core cannot cope
with the high frequencies. The current directly
to the batteries rises higher and higher.
Does anybody know, if there is much current
wasted inside the transformer, after it stops
giving more than 2 amperes out?
(We cannot measure AC currents going
in the transformer.)
Another question:
We found another transformer with a ferrite core.
Does anybody know if there is any limit for this kind of transformer concerning
the frequencies it can cope with?
- Hannu |
86 Scoop users have viewed this posting.
