| The generator consists of two three phase delta wound alternators, mechanically offset 60 electrical degrees to reduce cogging. The outputs are individually rectified and then wired in series inside the nacelle at the tower top. They could easily be parralleled at this point for lower voltage higher current. The generator, rectifiers, nacelle cover, mainframe, and tower stub are in good condition both electrically and mechanically. The plastic ( nylon?) yaw bushings need to be replaced and the sliprings and brushes need some work. The original blades are unusable except as patterns. The tail is missing. Asking $400.
Make the wind fun!
Victor |
98 Scoop users have viewed this posting.
