HI!!!
10 watts doesn't seem like much, but when one builds it from a chunk of aluminum, some fiberglass and a handful of solar cells, it really means a lot!!!
Those Silicon Solar cells I posted about a while ago finally got put to use! After a day's worth of machining, etching copperclad fiberglass, and a whole lot of soldering, the panel is complete. It is sitting in the sun right now, charging my batteries, and running a small portable tv.
I used the technique I explained a couple of posts back about copperclad pcb solar panels. It turned out to work very well! I made little 1 volt 2 cell boards, and then epoxyed them on the the machined aluminum, and soldered them all together without putting any stress at all on the cells. Not one cracked, and all are performing flawlessly! I will have pictures shortly.
Hopefully more of these to come!!!
Already have over $400 in the solar panel budget. By this time next year, my whole house will be off grid!
-Andrew |
97 Scoop users have viewed this posting.
