I just wanted to post this becuase I tried this recipe and found it works good for Bio Diesal.
First off all screnn out 40 gallons of WVO
second pump it into a 55 gallon drum
third add 4 gallons of kerosene to it
fourth using a subermissible bildge pump let it stir for 24 hours
fifth let stand for 48 hours
sixth pump out from the top down to the last 4 inches in the barrel into a clean barrel
Now you have a fuel that well run in a diesal engine for the small amount of about 20 cents per gallon, I have been doing this for almost a year and have found it works good, and have had only one problem with it, I found that at first I went through 4 fuel filters before I didnt need to change them anymore. Hope this helps somebody out. |
