Greetings,
Here is what I was talking about with a mechanical inverter.
This is an end view of the rotor and brush setup I mentioned in an earlier thread. The colored lines are connections between the commutator positions. As the commutated rotor spins the direct current is redirected in an alternating current fashion. A really small motor could be used to turn this rotor as only the brush resistance is a factor (in my tiny mind anyway :-) ). The brushes are on the sides and top, no feed or supply wires shown. I think for 60 hrtz the RPM would have to be 3600, but it could be half that(it's late in the day). Or with more commutation slots far less RPM.
I think that 12V DC could be fed to this with the addition of the stepup transformer on the AC side. I feel, but don't know, that if the right size motor run capacitors were used on the AC side this could make some pretty good quality AC.
What do you guys think?
RogerAS |
