Difference beetween 12V and 24V
By Guerreiro, Section Homebrewed Electricity
Posted on Wed Nov 5th, 2003 at 02:59:34 AM MST
<a href="http://www.fieldlines.com/">http://www.fieldlines.com/</a>
Can anyone help me with the following:
In order to build a PMG I've been searching in several places and I've found some very good tips, mainly from Mr. Hugh Piggott. However I've been having a question:
In the PMG, what should I modify in order to my output be 24V or 48V and not 12V??
Is it in the coils or in the bridge rectifiers??
If it's the coils is it in the number of turns, the thickness of the wire, or in booth??
Thank you everyone
Guerreiro
Difference beetween 12V and 24V | 3 comments (3 topical, 0 editorial)
Re: Difference beetween 12V and 24V (none / 0) (#1)
by zubbly on Wed Nov 5th, 2003 at 04:01:58 AM MST
(User Info) www.zubbly.com
hello Guerriro.  the best i can offer here is direct ratio.
to double volt, you double turns and 1/2 the size of wire
to triple volt, you triple turns and 1/3 the size wire
to quadruple volt, you quadruple turns and 1/4 size wire
your amp output will follow the decrease in wire size.   double voltage=1/2 amp output and so forth.
easy way to calculate 1/2 wire size is to count up 3 sizes.  1/2 of #14=#17, 1/4 of # 14=#20.  to be sure consult a magnet wire chart that gives circular mills of wire size.
if anyone has a difference of opinion with regards to ratio of turns versus wire size, please jump in.
have fun-----zubbly
Re: Difference beetween 12V and 24V (none / 0) (#2)
by Guerreiro on Wed Nov 5th, 2003 at 10:23:59 AM MST
Thanks it was very well explained, very simple for me to understand
Guerreiro
Re: Difference beetween 12V and 24V (none / 0) (#3)
by desertratjack on Thu Nov 6th, 2003 at 08:24:06 AM MST
It could be that wiring the coils in series will raise voltage and in parallel raise amperage, but I have wondered if the wiring size  on PMA's is a good indicator of the intended voltage output- probably so.
  92 Scoop users have viewed this posting.
· Also by Guerreiro
