Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Reviews
Diaries
Our Products
ceilingfans to windmill....?
By
1 Roach
, Section
Posted on Thu Nov 06, 2003 at 09:23:03 PM MST
anyone made a windmill from a ceilingfan, can it be done. ?
3
comments (3 topical)
Re: ceilingfans to windmill....?
none / 0
#1
by
dburt
on Fri Nov 07, 2003 at 05:46:59 AM MST
I tried this, machined the rotating part out to fit in some magnets, and bolted on blades. The frustrating part was that the original coils were of really tiny wire, varnished so it was near impossible to change the way the coils were connected (they were all in series to begin with). At any rate, I found that the thing cogged pretty bad, takes a stiff breeze to get it spinning. I decided that my time would be better spent building a dual rotor axial machine similar to DanB's.
Dave
none / 0
#2
by
1 Roach
on Fri Nov 07, 2003 at 04:13:47 PM MST
thank's for the info.on the fan....i'm still looking to do something.maybe ( an alt} back to the board. thanks again.
none / 0
#3
by
santi
on Sat Nov 08, 2003 at 08:52:48 AM MST
I rewired and add magnets to a ceilingfan, it had two phase 14 poles in a waved wound, i use 100 turns of about 0,5 mm wire, and add ceramic magnets. I have 12 v at about 120 rpm with to phase rectified and then in series, and the max. amp. i have seen is 1,5 amps, with neos sure can be more; with ceramic magnets its low cogging, but with neos can be higger; probably if you put a diferent number of magnets than poles diminish cogging.
Parent
3
Display:
Threaded
Minimal
Nested
Flat
Flat Unthreaded
Sort:
Unrated, then Highest
Highest Rated First
Lowest Rated First
Ignore Ratings
Newest First
Oldest First
create account
How to use the board
FAQs
search the board
Google search the board
Scoop users have viewed this posting.
Also by 1 Roach
