Hornet looking blades verses others we found.
By cheap power, Section Homebrewed Electricity
Posted on Thu Dec 11th, 2003 at 04:08:37 PM MST
Maybe its the blades?  Ours looked like the ones the Hornet uses.  We got a gray 4 blade set off ebay and now we are charging! Cindy
We found that different blades help.  A while back we bought a 6 blade set off ebay, they look like the same blades the Hornet uses (black pointed lawn darts my neighbor calls them). We ran those blades for about a month and never got our batteries charged up even in strong winds. We recently bought a gray 4 blade set off a guy on ebay for 70 dollars and found them to be worth every penny.  We had a couple of questions and the guy was there to help.  We took the pointed 6 blades down and put up his 4 blade set and now our batteries are charging!  Those gray blades are a lot lighter and go so much faster than any of the other blades we have tried.  They run fast in hardly any wind at all.  Maybe they just need different blades?
Cindy
Hornet looking blades verses others we found. | 8 comments (8 topical, 0 editorial)
Re: Hornet looking blades verses others we found. (none / 0) (#1)
by ibedonc on Thu Dec 11th, 2003 at 05:02:41 PM MST
I saw those , they looked like they were cut from PVC pipe
Re: Hornet looking blades verses others we found. (none / 0) (#2)
by cheap power on Thu Dec 11th, 2003 at 07:03:26 PM MST
They may have been, all we know is they work better than anything we tried yet.  I saw he has a 5 blade now.  I wonder if it would be better yet than the 4 blade one??
Who knows.
Re: Hornet looking blades verses others we found. (none / 0) (#4)
by troy on Fri Dec 12th, 2003 at 08:54:25 AM MST
Keep in mind that, all things being equal, more blades on a rotor mean better torque but LOWER RPM's.  Many people find that a 2 or 3 blade setup makes more juice than a four or five or six, assuming they are all the same diameter and airfoil.  But, as mentioned, it also depends on your mill and what the mill wants for RPM and torque.
Good luck and have fun!
troy
Re: Hornet looking blades verses others we found. (none / 0) (#5)
by cheap power on Fri Dec 12th, 2003 at 06:28:56 PM MST
What you said makes sense but I dont think the lawn dart blades ever turned as fast even when the wind was blowing hard.  The difference is like day and night on speed and they dont make noise like the lawn darts did either.  Today we didn't have much wind but our new blades were doing their job.  We thought we understood that more blades means you can start sooner.  I know the lawn darts wouldn't even be moving this wind.  For us more was way less.
Re: Hornet looking blades verses others we found. (none / 0) (#8)
by desertratjack on Wed Dec 17th, 2003 at 10:11:10 AM MST
It is probably true in general that more blades mean a lower speed but the Hornet sets are 6 blades and I think they turn faster than the Windseeker 2 and 3 blade mills. (6' diameter).
Re: Hornet looking blades verses others we found. (none / 0) (#7)
by desertratjack on Fri Dec 12th, 2003 at 09:10:17 PM MST
Like the ones here on otherpower?
Re: Hornet looking blades verses others we found. (none / 0) (#3)
by RobD on Fri Dec 12th, 2003 at 05:05:27 AM MST
Hi cindy,
Is this a 'homebrew' mill? A lot depends on your configuration.
RobD
Re: Hornet looking blades verses others we found. (none / 0) (#6)
by cheap power on Fri Dec 12th, 2003 at 06:32:44 PM MST
Yes it is.  Our neighbor helped us get it going.  He has all the tools and things.  It was an Amteck 40 motor we used.
We are learning as we go but it has been fun.
  80 Scoop users have viewed this posting.
· Also by cheap power
