Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Reviews
Diaries
Our Products
looking for h2o heat
By
outback
, Section
Posted on Sun Mar 30, 2003 at 04:25:09 AM MST
hey all,i was just wondering if someone could point me to some sight using water for heat.
5
comments (5 topical)
floor heat
none / 0
#1
by
Ramblyr
on Sun Mar 30, 2003 at 08:40:50 AM MST
Here is a link to a pdf file which might help. http://www.hotwaterproducts.com/HTP/Pdfs/925%20controlled%20munchkin.pdf I am doing hot water heat in a garage at present which iam useing a gas hot water heater an expansion tank,temp sensor,a bleed valve to remove air,and a grundfose pump,a line voltage thermastat,and about 300 hundred foot of pex tubing which is tied to the wire in the concrete.You should use about one foot of tubing per one square foot of floor space.You would probably be better off buying product from a heating and plumbing supplier tha on the web!I have tried to find good info before but couldnt. Cant figure out how to post a pic!
Ramblyr
radiant floor heat
none / 0
#2
by
Anonymous Hero
on Wed Apr 02, 2003 at 10:01:12 AM MST
My next house will use radiant floor heating, so I've been doing the research on the proper tubing, pumps, solar assist, etc. Nice to know someone got the job done. Any specs on your pump? The tubing itself is cheap enough, it's all the commercial control circuitry that costs a fortune. thanks, troy
base board heaters
none / 0
#3
by
Anonymous Hero
on Fri Apr 04, 2003 at 04:44:09 AM MST
thanks for the comeback fellows.i didfn't make my self clear as usesall.what i'm trying to find is water baseboard heaters.does anyone know of a sight that sells these.or better yet has plans to build them. thanks outback
Hot Water Heat
none / 0
#5
by
Ramblyr
on Sun Apr 20, 2003 at 07:45:35 AM MST
Here is a site with some nice units which you could put on your outside walls, http://www.aimradiantheating.com/store/slimline.html or you could epoxy tubing to allunium strips or solder copper pipes to copper strips,you could make a press for alluminum or copper by notching a piece of wood say half an inch then for experiment sake try a strip cut out of a beer can laying it over the wood and pressing it with a dowel rod down into the groove that way makeing a snap on fin system, you can also buy these for under floor heat! Good luck
Ramblyr
Parent
problem
none / 0
#4
by
Anonymous Hero
on Fri Apr 04, 2003 at 04:49:03 AM MST
am i doing something wrong posting i have an account [outback]but when i post it shows up as Anonymous Hero.help
5
Display:
Threaded
Minimal
Nested
Flat
Flat Unthreaded
Sort:
Unrated, then Highest
Highest Rated First
Lowest Rated First
Ignore Ratings
Newest First
Oldest First
create account
How to use the board
FAQs
search the board
Google search the board
Scoop users have viewed this posting.
Also by outback
