| I've got a source on failed hard drives so have about 16 of the crescent shaped magnets out of these. These look very similar to the #31 magnets at Forcefield. (I can get more as hard drives in our school system fail.) My only cost is the sweat of getting them out of the defective drives and listening to my wife complain about the mess I make while doing it. SOP.
I'd say these magnets are about an inch and a quarter in width and maybe a half inch from the bottom of the curve to the top. They are slightly thicker than a quarter. They come on a bracket with holes that make it easy to attach them to a surface without damaging the magnets. They are NdB, I believe, with a nickle plating. One will easily hold a large set of vice grips or a carpenter's hammer. Getting two of them apart requires quite a bit of effort and they'll bite you pretty hard if you get a finger between them.
The issue is that they have a N and a S at either end of the crescent shape. Imagine looking at a flat piece of unused chewing gum. One end is N and the other is S.
I bought some #20 coil wire at a motor rewinding shop and made up several coils with perhaps 100 turns of wire. (#20 seemed a good compromise size.) These coils are perhaps 2 inches long and just slightly wider than the magnets (maybe an inch and a half.)The coil resistance measures at about 4 ohms.
I mounted 8 of the magnets on a plywood disk eight inches in diameter. It has a hole in its center. I put a bolt through it and put it in my hand drill. I spun the drill up and tried holding one of the coils up as close as possible to see what kind of meter readings I'd get.
The bottom line is that the results weren't all that good. A few millivolts was about the best I could get - even when the gap was very close. I'd guess the drill is turning at maybe 2 or 3 hundred RPMs. Something seems to be wrong. So I'm back to the drawing board.
Has anybody successfully used these magnets in a wind genny? If so, how did you arrange the coil to magnet arrangement? And what kind of results did you get? I figured to use a two blade prop, perhaps at 48-60 inches (total).
As always, any help and advice is appreciated.
Maybe I'll get used to the new board. But I'm still in a steep learning curve.
Bach On! |
65 Scoop users have viewed this posting.
