I just got a old stihl weed eater motor. The thing was trashed! After an afternoon of fixing up the piston, the recoil unit, I got it running! Just need to adjust the carb to allow lower idling speeds. The nasty oily smoke though just screamed for the engine to be converted to ethanol. (I know one distributer down here in Colorado Springs, on 8th street I think) So, I was told that I need to adjust the carb for a richer mixture of ethanol/oil mix. How do I go about this.
Finally, anyone know a alcohol soluable oil for 2 cycles. If so, what proportions should I mix?
-Andrew
P.S.
The Machining process of the tiny ethanol engine is progressing! Got the pistons and the crankcase done. But when I went to machine the head I found out I have a chipped reamer! Looks like I'll have to take it in the shorts and buy a 3/8ths reamer and a 1/2 one too. (Anyone know any good machine tool places for internet order?) (3/8 needed for valve assembly) I'll keep you posted as both projects progress.
-Andrew |
44 Scoop users have viewed this posting.
