slip rings
By Chuck, Section Homebrewed Electricity
Posted on Fri Jul 18th, 2003 at 11:42:39 AM MST
I've posted a diary entry on building slip rings
For those interested, I've posted a diary entry on a homebrewed slip ring solution. I just couldn't take the dangling, twisted wire method any more.
http://www.fieldlines.com/?op=displaystory;sid=2003/7/18/11222/7109
slip rings | 4 comments (4 topical, 0 editorial)
Re: slip rings (none / 0) (#1)
by electronbaby (roy<at>windsine.org) on Fri Jul 18th, 2003 at 11:53:38 AM MST
Very nice!!  Have you tried it out yet?? Just curious to see how it works. Ive always wanted to do something like this but I guess I have been lucky so far in not needing them. But maybe soon. Nice job.   :-)            RoyR
Have Fun!! RoyR KB2UHF
Re: slip rings (none / 0) (#2)
by Chuck on Fri Jul 18th, 2003 at 12:50:45 PM MST
(User Info) http://home.morrisonprairie.com
Hi Roy,
I've wired it up and tested by spinning the generator while rotating the tower stub. I rocked it around a bit to make sure the brushes keep in contact with the rings. It transfers the power well from what I can tell with just a volt meter.
Assuming I can get new blades balanced this weekend, I hope to have it installed and working fairly soon.
Chuck
chuck
Re: slip rings (none / 0) (#3)
by electronbaby (roy<at>windsine.org) on Fri Jul 18th, 2003 at 01:40:20 PM MST
cool. Sounds good. Im interested in seeing it when your done. Post the final info, and keep having fun!!         RoyR
Re: slip rings (none / 0) (#4)
by iFred (ifred2006@yahoo.com) on Fri Jul 18th, 2003 at 05:20:04 PM MST
AHHHH HAAAAA!!! Now thats usefull, Thanks for sharing that! Very slick design, simple, common parts, I was running into the same problem. Good Job Chuck!!!! I can't wait to see what your jenny does when she's up and runn'n. I wish you the best! Keep us informed and let us know how it goes.
  74 Scoop users have viewed this posting.
· http://www.fieldlines.com/?op= displaystory;sid=2003/7/18/11222/7109
· Also by Chuck
