| Hi folks,
I'm in the final stages of making my generator innards. Still no prop, but I'm ready to plan and build my furling system.
One concern I have is that we are subject to occasional hurricanes that blow inland in the late Summer and early Fall. It isn't that unusual to get winds approaching 75 mph during such storms.
I've read what many have done with furling mechanisms. Yes. I did a search.
Let me check my limited understanding:
One popular method is to use a tail that is offset perhaps 20-25 degrees from the plane of the prop. I believe DanB has used this on his most recent projects. The method seems to be to have the prop turn out of the wind when the windspeeds get strong enough to push the tail and spin the alternator mount. The tail must be of an appropriate size and weight so that the furling takes place at the correct wind speed. Determing the size and weight may take some trial and error.
Seems like I've seen where some also use a movable tail. Mike, for example, uses old TV antenna rotors to adjust the tail. I'd guess this allows you to adjust the windspeed at which the prop is turned out of the wind. Does this sound correct?
Seems like I've also seen that some make their furling system so they tilt or swivel. I do not really understand the advantage to doing this.
I'd be greatful for any and all comments and advice from some of the experienced builders.
I continue to be very impressed by the collegial spirit here.
Bach On |
