| hello all.
I have a perplexing question to ask. is it possible to tell the output from an inverter without a scope? reason I ask is that I have acquired an older (1989) 800W ups unit, it is an alpha-800 power source and runs from 36v. I will be adding this into my basement system mainly because it has a functioning charger and if I can keep 36v of my batteries charged thats great. but the main problem I have is trying to figure out what waveform it uses and without a scope i'm at a loss! best I can tell is the output stage is using bipolar transistors going into a large transformer and I would imagine it could have a sinewave drive but not sure without tearing it to bits to trace out the board. also the manual is no help, just says not to run highly capacitive or inductive loads because it won't handle the surge. |
