Please Referance this post for more info! http://www.fieldlines.com/story/2004/1/20/235135/142
K, so now this battery works even with water. I get 1 volt dc out of it. Time to make something bigger. Stay tuned!! This will be neat.
P.S. Still rechargeable with water?? WeirD!>> all energy used to produce this comment or post came from solar and wind energy! It works!
Have Fun Windstuff Ed Have Fun! Windstuff Ed[ Parent ]
Galvanic currents are generated by two dissimilar metals immersed in water. If they are in close proximity to each other they will generate a voltage potential.
Water has resistance to current flow, any form of acid or chemical can either increase or decrease the electrical resistance of the water. This solution is called an electrolyte.
Maximizing the size of the plates should also increase the current flow and voltage. >> all energy used to produce this comment or post came from solar and wind energy! It works!
Use 1/2c water, 1t vinegar, copper wire, galvanized nail. Drill 2 holes in popcicle stick, put nail and wire through it. Place popcicle stick over glass container with water/vinegar in it so both nail and wire are in the solution. Hook voltmeter, + to copper and - to nail.
One made about 0.8v. We made 2 in series and the volts added together and we got about 1.6V. --
http://www.fieldlines.com/comments/2003/7/22/65219/8617/11#11
- Hannu[ Parent ]
