| Well, after thinking about this and also not knowing if my laminate idea will work (in terms of it pulling apart due to the forces of magnets or mounting problems) I have also decided to build a stator with no laminates. Besides no laminate in the second stator, it will be the same as the first stator in terms of wiring, coil size, amount of turns, and total coils.
Given the number of coils, there will be no open areas in the flux path as is the case with most double magnet rotor(three phase)generators. Most of those designs use large coils which end up being a bit on the fat side, thus making the gap between the two rotors very large and leaving a huge hole in the center of the coil where there is no magnet wire to capture the flux. This in my opinion is a waste of possible power output in the design.
doing the coils the same way I was planning on doing them with the slotted steel laminate, I have many thinner coils which will overlap on the top and the bottom legs of the coils. Since the overlapping occurs on the top and bottom of the coils (away from the magnet path), the side legs (the ones in the path of the magnets and thus the flux) can lay flat. This also utilizes all space in the stator by not leaving areas where there is no magnet wire to catch the flux of the magnets. Doing it this way makes the stator thickness minimal. Given the size of the coils, I think i can even put in the extra set of coils (as I originally planned in the slotted steel laminate design), and still have a thinner stator than most double magnet rotor designs with the standard three phase design.
I plan on building both stators, and then test the difference in output. I suspect that the non-laminate design will be far easier to build and have much less problems to overcome, but perhaps about twenty percent less efficient.
But, given the losses assosiated from cogging and eddy currents, perhaps the laminate-free design is the way to go.
Devon |
112 Scoop users have viewed this posting.
