Starting the Listeroid diesel
By DanB, Section Homebrewed Electricity FAQ
Posted on Mon Oct 18, 2004 at 08:20:53 AM MST
when it's really cold....
I'm certainly not wanting to spread bad or dangerous advice.  It's been getting pretty cold up here at nights lately.  When it's real cold (like 20 deg) - I can start the engine, but it takes a lot of cranking and leaves me totally 'wiped out'... I suspect  if it got colder (which it will)... perhaps 0 deg, it would be impossible without either heating the intake, installing a glow plug.. or something like that.
My neighbor up the hill charges his batteries with a single cylender Volvo diesel hooked to a generator.  His simply wont start below about 50 deg (my Listeroid starts on the 1st crank at 50 deg).  He tells me that the 'easy' way is a little ether (starting fluid).  Almost everyone else tells me thats 'crazy'...  it could damage the engine, it could kick back.
At any rate, sometimes 1st thing in the morning I have pretty limited patience.  We use the Lister to pump water into our cistern from a deep well (we've got a 240VAC well pump).  It's pretty common, that when the girls wake up here we run out of water (they use lots first thing in the morning) and I have to start the generator (often times before my 1st cup of coffee).
For about 2 weeks now, I've followed Tim's advice and used just a 'touch' of ether.  By 'touch' I mean... the very smallest amount that you can actually get out of the can - I spray it for a small fraction  of a second.  And.. so far, no matter how cold it is - it always starts on the first crank and it's never seemed the least bit inclined to kick back.
Perhaps I'm crazy... but it sure seems to work nicely!
Starting the Listeroid diesel | 0 comments (0 topical)
  123 Scoop users have viewed this posting.
· Also by DanB
