Wind power air compressor?
By Farmer, Section Wind Posted on Sat Oct 23, 2004 at 01:15:33 AM MST
Has anyone built a wind powered air compressor?? Should this be here or remote living?
| There are many tools that can be run on compressed air. Many of the Amish use compressed air for kitchen appliances, fans, shop tools etc...
A no longer certified propane tank makes a great air tank with large capacity.
Why not make a windmill that powers an air compressor? By storing compressed air I could reduce the size of the battery bank I need. Air tanks have a far longer service life than batteries and cost much less to purchase. Used tanks can be acquired for next to nothing.
I suppose that to obtain the higher pressures a reduction system would need to be used to obtain enough torque to drive the compressor. But what if a sail type windmill similar to the dutch pump mills was used. I imagine those huge sails generate incredible torque.
A small mill that only generates up to 30psi intended for aeration of a pond.
http://www.malibuwater.com/oAirCompressor.html
Air lift pump for pumping from wells, no data on psi generated.
http://www.realgoods.com/renew/shop/product.cfm?dp=1900&ts=3041712
I suppose another option is to use the wind to make electricity and power an electric compressor directly without running through a battery bank.
I cannot find any more material on google, perhaps I don't know the proper search terms.
I want an wind powered air compressor which will produce 125psi or more. |
198 Scoop users have viewed this posting.
