Blade thickness question
By daleh007, Section Wind Posted on Tue Oct 26, 2004 at 12:48:52 PM MST
Does the max. thickness move towards the trailing edge as you move towards the root?
Looking at some drawings of the bottom side of a rotor it appears that the max thickness runs parallel to the leading edge. In the descriptions I've read it says to draw lines at 30% and 50% of the chord width from the leading edge. If you do this you get lines that move away from the leading edge as you approach the root. Is this correct?
Daleh |
65 Scoop users have viewed this posting.
