3 phase
By outback, Section Homebrewed Electricity
Posted on Wed Oct 27, 2004 at 03:53:35 PM MST
need experienced help
i'm trying to hook up my 3 phase stator coils.they are all wound clockwise.do i connect them start end start end or start start ,end end. i thank anyone that can help. outback
3 phase | 7 comments (7 topical)
Re: 3 phase (3.00 / 0) (#1)
by old55olds on Wed Oct 27, 2004 at 05:48:04 PM MST
We need mor info than that. How many coils in each phase? How many coils total?
Re: 3 phase (3.00 / 0) (#2)
by outback on Wed Oct 27, 2004 at 06:01:45 PM MST
i'm sorry duh,
     there is 8 magnets 24 coils
You can lead a horse to water,but you cant make him eat the trough.
Re: 3 phase (3.00 / 0) (#6)
by Flux on Thu Oct 28, 2004 at 01:57:38 PM MST
You have one coil per magnet per phase.
Every third coil belongs to the same phase. For each phase you need to reverse alternate coils as they are under opposite poles .
The finish of the first coil goes to the finish of next one, then the start of that goes to the start of the next one and so on.
You also have to watch which ends you use for the three phases.
If you call the first coil phase a, second coil phase b and third coil phase c, ( which is the easiest way to do it), the phase displacement is only 60 degrees so to correct this you need to cross the start and finish leads of the middle phase.
Sorry this is confusing in words, but I don't have any diagrams.
Re: 3 phase (3.00 / 0) (#3)
by windstuffnow on Wed Oct 27, 2004 at 06:07:19 PM MST
  Try the info on my 3 phase educational turbine basically wired the same way... with the exception it uses 6 magnets and 18 coils...
http://www.windstuffnow.com/main/3phase_turbine_kit.htm
At the bottom of the page there is some instructions for the kit in .pdf format and is about a 50k download.  might help
Have Fun
Have Fun! Windstuff Ed
Re: 3 phase (3.00 / 0) (#4)
by outback on Wed Oct 27, 2004 at 06:36:43 PM MST
thanks ed i read your email but cant open the file,it will download but in code.maybe i just dont no how.
Re: 3 phase (3.00 / 0) (#5)
by wind pirate on Wed Oct 27, 2004 at 10:50:17 PM MST
DanB Did a real nice drawing of the wiring three phase. See this link to the archive.http://www.fieldlines.com/story/2003/9/11/84741/6758
You have 8 magnets and 24 coils, and generally a 4:3 ratio is used i.e. 12 magnets / 9 coils. See the articles on the front page about Dan's big machines. They are all wired 3 phase.
Hope this helps
Wind Pirate
Re: 3 phase (3.00 / 0) (#7)
by hvirtane on Thu Oct 28, 2004 at 03:47:55 PM MST
Some explanations also here:
http://www.fieldlines.com/story/2004/6/2/163021/1860
· Also by outback
