| I am making another wind Generator. I have just recieved sixteen wedge shaped neos and some silicone steel for my laminate.
It will be a slotted stator design such as the design that Ed from windstuff now has done. There will be three single phases of coils (sixteen coils in each single phase)equalling 48 total coils. The coils will be six turns a piece, the biggest wire that will fit in the slots (Ed thinks no 14 will be the one, I guess time will tell).
The magnet rotor will be a 12 inch disk, the blades 8foot diameter at tsr of 8 I think, not sure on the tsr as of yet either.... about the only thing I am sure of so far is that it will be of the slotted stator design, 12 inch magnet disk, sixteen magnets, three single phases, 48 coils total. This is the basic design, and I will get started building this part of the project this weekend.
OK, so I have gotten a little power crazy here and have begun to think of more possible output, and have decided that I may want to also slot the back side of my laminates, so that I can fit coils on the back of the laminates and the front.... and then add another 12 inch disk and another sixteen magnets. I would line the magnets up where the poles of the magnets facing each other are the same and perfectly alligned with one another.
As far as the slots on the steel laminate, I will offset them from the front side. The reason for this is so when the front side is in the position where the cogging is the worst, the back side is not experiencing the cogging affect at all and vise versa.... The thought is that perhaps the cogging effect will in essense "cancel" itself out... but, even if this is not the case, at least the cogging effect is not doubled due to both sides cogging at the exact same time.
I will also keep the sides totally seperate from one another until after they are rectified. In other words, it will be two seperate alternators, only sharing the laminate and the force of the props.
I am thinking that I will use steel disks for the magnet rotors rather than car brake rotors in order to cut down on some weight in the design....
Oh, and of course the furling tail.
I figure if I could pull this off, no way I won't be making enough juice for that stupid fridge.... at least that is the hope anyway. I will still have to buy some more battery power too.
Hope I explained this good enough to envision..... what do you all think?
devon |
