ceramic v.s. neodymium
By Paulm, Section Homebrewed Electricity
Posted on Fri Nov 12, 2004 at 07:29:32 AM MST
are ceramic just as good?
For my first induction motor conversion I'm trying to keep cost down cause I don't know how well things will work out. Ceramic magnets are so much cheeper than neos. I they are not as strong but will they still work ok? Most PM motors seem to use ceramic magnets for the field. Anyone have some experience with induction motor conversion with ceramic magnets ?
ceramic v.s. neodymium | 4 comments (4 topical)
Re: ceramic v.s. neodymium (3.00 / 0) (#1)
by troy on Fri Nov 12, 2004 at 07:49:15 AM MST
Good ceramic magnets will be lucky to produce half the output compared to neodymium magnets, and a third would be more likely.  Neodymium magnets are astounding in their flux density. That doesn't mean ceramics are inappropriate for your application so long as you account for the difference in strength.
Good luck and have fun doing it!
troy
Re: ceramic v.s. neodymium (3.00 / 0) (#2)
by fuzz on Fri Nov 12, 2004 at 02:41:31 PM MST
As troy stated, less power but using ceramic magnets could give you some advantages, its cheaper and less cog effect.
In my opinion are ceramics more suitable for a smaller windmill if you want to use a converted induction motor
fuzz
Re: ceramic v.s. neodymium (3.00 / 0) (#3)
by ghurd on Fri Nov 12, 2004 at 07:53:32 PM MST
Can you give some more advantages?
I'm doing a 1/30hp neo conversion and worry about stalling.  This would only need bigger blades, but I don't get much else.
Ghurd.info
Re: ceramic v.s. neodymium (3.00 / 0) (#4)
by tecker on Sat Nov 13, 2004 at 04:51:07 PM MST
   You can get some time energy with really large ceramics (longer duration  in potiential ) which translate to more amperage
  96 Scoop users have viewed this posting.
· Also by Paulm
