Angle grinder to cut rotor
By Paulm, Section Homebrewed Electricity
Posted on Thu Nov 18, 2004 at 08:25:17 AM MST
Or pay for lathe ?
I'm doing an induction motor coversion. I need to get the rotor cut down to glue on the magnets. The magnets are no more than a quarter of an inch thick. I don't have a lathe to cut the rotor. Do you think I can cut down the area for the magnets with an angle grinder and leave the rotor alone where no magnet is mounted? I'm putting on 4 magnets evenly spaced.
Angle grinder to cut rotor | 4 comments (4 topical)
Re: Angle grinder to cut rotor (3.00 / 0) (#1)
by juiced on Thu Nov 18, 2004 at 08:36:56 AM MST
Im not entirely sure about this answer, but i have built a couple 'fine' knives (more like shiny, bear-sized k-bar/katana) and i had nothing but grinders to use for cutting.
    In my knive making experiance it produces a cheap blade due to temperatures inflicted on the metal. However, if you can keep the shaft cold; i think it would work as well as you can. (if you are carefull and patient it should turn out well)
   Actually... i used a acet. torch to pierce the hand guard as well.
  Hope the pic works.
Canada's -Debatable- A.E./R.E Debate Site
News, discussions and debates!
www.juiced.ca
Re: Angle grinder to cut rotor (3.00 / 0) (#2)
by juiced on Thu Nov 18, 2004 at 08:49:37 AM MST
 This time it should.
www.juiced.ca
Re: Angle grinder to cut rotor (3.00 / 0) (#3)
by juiced on Thu Nov 18, 2004 at 08:59:30 AM MST
i see no reason the pics arent working. might be my server, but other pics on OP served from my end are still working. (oh well, not my thread. I just wanted to show you that results can be had)
www.juiced.ca
Re: Angle grinder to cut rotor (3.00 / 0) (#4)
by baggo on Thu Nov 18, 2004 at 10:14:22 AM MST
Hi Paul,
It would probably be easier, quicker and less messy to just cut 4 flats on the rotor with a hacksaw and clean up with a file. The metal laminations on the rotor are usually fairly soft and should be easy to cut. I'm assuming that your going to use flat rectangular magnets.
John
  95 Scoop users have viewed this posting.
· Also by Paulm
