stator questions
By phil b, Section Wind
Posted on Mon Nov 22nd, 2004 at 04:21:23 PM MST
new stator has 'islands'
I poured this stator yesterday. It seems all of the stators I pour have the same problem. They develop 'islands'where the mold does not touch the resin. I put about 60 lbs on them and I get about a half cup resin coming out both sides. I put a straight edge across it and it is straight except for the areas with not enough resin. Possiblt an air pocket??
The coils and the fiberglass cloth are completely covered. So I guess there's no real problem except they look shabby. How can I correct this?
stator questions | 2 comments (2 topical, 0 editorial)
Re: stator questions (3.00 / 0) (#1)
by Flux on Mon Nov 22nd, 2004 at 04:39:27 PM MST
Seems like trapped air. Try vibrating the mould before the final squeeze. Hugh's idea of an sds drill seems a good one.
Regarding the previous post, I like your bale counter, neat idea.
Re: stator questions (3.00 / 0) (#2)
by iFred (ifred2006@yahoo.com) on Tue Nov 23rd, 2004 at 04:25:33 AM MST
After I pour my mould I carefully ( i do mean very carefully) shake the mold a bit, then I use a needle and pop out all the air pockets before I put the top on, seems to correct the problem. I use a more transparent type resin though that allows me to see right through durring the entire process. You could use maybe a vibrating sander, never thought of that one!
· Also by phil b
