Some of the 'old' experienced guys here
have built quite big wind turbines.
They are using them for heating
purposes.
I think that the biggest challenge
is to make big blades. The rest of
the machine is simpler.
It is maybe
easiest to use a gearbox and a
standard generator.
However, I think that it is as well
possible to make even a 10 kW direct drive
generator yourself either by an induction
engine conversion or by using the axial
permanent magnet generator approach.
Two approaches for big blades.
Tube wire blades.
These blades are waiting for a reinstallation.
They have been in use for 6 years without
any problems in Finland. They were designed by
Kyösti Juvonen and built by him and by Risto Ruppa. The dimensions of the blades are in
the next picture.
The blades are built with a tube wire method.
The tube inside the blade is tapered.
The fixing system of the blades is made
really strong.
Blades of wooden strips.
The idea for these blades comes originally from
a man called 'Reinikainen'. Here is a picture
of one of his original machines. The rotor is
7,5 m in diameter.
This machine has been in use for more than ten
years in Finland. At the tips of the blades
there is coating with fiberglass. The blades are
made of wooden boards.
We have later made some experiments with that
system of building the blades. With Taisto
Suihkonen we have made a wind rotor of
3 m diameter with four blades. Taisto made
an experimental airfoil for those blades.
More details about those blades in my diary.
http://www.fieldlines.com/story/2004/6/2/163021/1860
We made also with Erkki Nousiainen
a quite big set of blades with a similar
design. The diameter of these blades
is 10 m. The rotor is with two blades and
we made on the tips of the blades an airfoil
according to the airfoil shape K2 as published
by Hugh Piggott.
Partly the idea to make the blades
wider on the tips is based on the GGS
theory by Gorlow and others (besides
the easiness of the construction). According
to the GGS theory the air is flowing
towards to the tips of the blades,
so it might help to make the tips wide...
Here is a picture of the blades under
construction at the workshop of
Erkki Nousiainen.
Another picture of the blades
under construction to show
the idea how to get the airfoil shape.
The blades are now flying up there
on the tower. The rest of that wind turbine
is a quite old construction originally with
a pitch control system, which is not
in use at present.
I will post some pictures of
the complete wind turbine,
when got them from Erkki
or from other friends.
In principle and in practice
the blades seem to
be working well, but I have
no measured figures yet.
- Hannu |
174 Scoop users have viewed this posting.
