We just shut down the machine in high winds (up to 60 mph), doing about 600...700 rpm in one very short very fast gust of wind. It was clear the feathering did not work as it was designed to do and I did not feel like doing destructive testing :)
Amazing how variable the wind is though, that burst came out of nowhere in what was otherwise a 30 mph wind...
The mill is riding idle right now - shorted windings - until the wind dies down and then we'll start it up again.
At high speeds we can still see some imbalance too, the tower starts to shake. One of my friends (Laurence) will come and shore up the one guy anchor that looks a little iffy next week.
So, todo list for when I get back:
reinforce tower with another set of guys to get rid of tower resonance or at least raise the resonance point to a frequency where it is no longer a problem
disassemble the machine, check for wear / damage
redesign governor, beef up base plate, better slide shaft, heavier weights, better blade attachement
reassemble with new governor
check blade flex for equality
build an indoor balancing rig
get another set of bearings, take seals and grease out, exchange bearings in machine with these 'balancing bearings'
rebalance the machine
disassemble (this time the governor should stay in one piece during disassembly) and remove 'balancing bearings'
reassemble with the 'real' bearings
remount on the tower, run more tests
Until then we will be running the machine in fairly low winds (up to 25 mph or so) only.
On the one hand this is a 'failure' of sorts, the feathering does not work properly, so there is a lot of work ahead of us (I think it's due to appearant wind on the 'back' of the blade stopping it from rotating freely towards coarse pitch). On the other hand it just survived a 60 mph burst of wind without feathering, which is pretty good. It gives me confidence that the design, once it's feathering properly will survive some pretty heavy winds without damage.
And, if it would not be shaking so much due to imbalance/tracking troubles then I would just let it run!
125 Scoop users have viewed this posting.
