| Does anyone have any views on PTTs. The only example of this type of wind turbine that I know of is the Andreau 100 kw machine built by Enfield Cables in the UK in the mid 1950s. The reason I ask is that I see that a Hungarian company has resurrected this type of machine and believes that it can improve on the poor performance attained by the Andreau.
I have coined the name PTT just to give this type of wind turbine a category name, there must be other ways of using air to transmit the energy from the blades to the generator. For example, could a wind pump be used to pump a fluid (air or water) backwards and forwards through a Wells Turbine, much like an oscillating water column is used on a wave machine? Or if you had a couple of rotary air vents or chimney cowls handy, could you put them at one end of a duct and by putting a hair dryer at the other end trickle charge a battery?
By typing in Andreau wind turbine in a search engine it can be seen by the sparse results that PTTs have been discarded, but should this be so? |
100 Scoop users have viewed this posting.
