Hi all! Just got my net back up after two hurricanes. Lost my net end of August!!!
One hurricane end of August and twenty eight days later another. It would have been great to find a way to store that power. Near the end of July, I was doing my first motor conversion with very poor output results. Thanks to Flux and Ungrounded Lightning Rod for helping me sort out the problems, suggesting that the ceramic mags I was using were probably not strong enough and to try using neos. I ordered some from this sight and have recently installed them. Here are some of the test results:
My original test in July was done at 850 rpm with a hand drill, but this was damaged in storm. New test results are done at 400 rpm with old mags and then redone at the same rpm with the new mags.
400 r.p.m.
ceramic mags new neos
individual coils open volts 6.70 v.a.c. 13.40 v.a.c.
star open volts 11.20 v.a.c. 21.30 v.a.c.
D.C. open volts 15.10 v.d.c. 27.25 v.d.c.
1 amp bulb load 7.30 v.d.c. 14.75 v.d.c.
1,000 r.p.m.
12 volt battery load 14.80 v.d.c.
@ 8 amps
I started working backwards carving my blades first. These are three blades, 10' diameter with a TSR of 7. I was planning to chain drive this at a 1:1 ratio, but now do not think this will give me high enough r.p.m's. Anyone with any gearing ratio that may help would be most appreciated.
Thanks again for all the support.
