Briggs charger automation up date
By Old F, Section Homebrewed Electricity
Posted on Sun Dec 5th, 2004 at 10:41:29 PM MST
Some parts came in and had some time to play : )
Some of the parts have come in and I have it key starting and manually charging.
What I am using is a car starter solenoid  wired to the  12 volt pm motor and a blocking diode a cross the solenoid contacts .
 I pick up from Harbor Freight  a Battery tester with a 100 amp test load an volt meter.
Paid only  13 bucks for it. And am using it to discharge the 12 volt battery used in testing.
You can only use it in 10 sec busts  then you have to let it cool off .
I took the battery down to 12.5 volts started the engine had the throttle set for an out put of 14.5 volts.
It start charging with 15 amps when the battery voltage top out at 14.5  I shut off the engine the battery
voltage was 13.7 volts. That really made my day :  )
Had some  more fun at the test bench  I had built a battery voltage monitor using the Lm3914 Bar/Dot  driver the one from Home power magazine.
 I clipped out  the LED that indicated  14.5V when lit and wired in its place a 5V relay with clamping diode  when I ran my bench power supply  to 14.5V the relay closed .  I will use this to turn on a 12V relay with a larger gap at the contacts for the engine kill switch . This will be a down and dirty until
The rest of the parts show up for a better charge controller.
I think I have stage one whipped  I can key start it and I have a way to kill the engine when the battery is
fully charged.
Stage two will be to tie in the PLC and getting it to start when the battery is low.
Old F
Briggs charger automation up date | 5 comments (5 topical, 0 editorial)
Re: Briggs charger automation up date (3.00 / 0) (#1)
by srnoth on Mon Dec 6th, 2004 at 07:32:03 PM MST
Cool. I'd love to hear a bit more about the voltage regulation circuitry. I've heard about it, but found it looked a bit difficult. How easy was it for you to make? I think I will definately need to build one for myself soon. Basically i'll need it to turn a relay off at about 14v and turn it back on at about 11.8, so that my batteries are never cycled too much. From this, one can then use relays to do anything - start/stop an engine, turn an A/C charger on and off. Is this similar to the circuit you are working on?
Keep us updated,
Cheers,
Stephen.
Re: Briggs charger automation up date (3.00 / 0) (#2)
by Old F on Tue Dec 7th, 2004 at 05:27:37 PM MST
Stephen
The Home power magazine Bat-O- Meter is a voltage monitor it uses LEDs  to indicate voltage from 11.5 volts to 16V in ½  volt increments and is not adjustable  all I did was replaced the LED at 14.5V tap with a  relay with a 5 volt coil to make a quick and dirty  shunt type regulator.
I am waiting for parts to build  the shunt regulator in Hugh Piggott wind turbine plans and on his web site.
This will give me two relays with adjustable voltage set points.
How hard are they to build? Well I have been home brewing and kit building for more years than I am willing to admit  :  )
 There both beginners circuits and I am surprised  that no one has put a kit together with PC board for sale that would make things a lot easier than scratch building them.
Either one will work for a engine kill switch to keep  the batteries from over charging.
I will use them for in puts to a PLC I am using a PLC so I can set the choke an have three start attempts
If the engine fails to start it will shut down and sound an alarm so as not to run down the batteries
Some thing that would be hard to do with just relays.
Have  fun
Old F
Re: Briggs charger automation up date (3.00 / 0) (#3)
by ghurd on Wed Dec 8th, 2004 at 08:04:06 PM MST
""There both beginners circuits and I am surprised  that no one has put a kit together with PC board for sale that would make things a lot easier than scratch building them.""
Don't know if this helps much.
Harbor Freight #46972 Alternator Tester.  $2.99
6 LEDs, 5.0, 12.0, 12.5, 13.0, 13.5, 14.0 volts.
They light progressively. At 14.1V all the LEDs are on.
About 1"w X .5"t X 5"l.
There site has a photo.
Had one apart couple years ago. Looked like it could be modified easy enough, but I went a different route, so never continued with it.
Re: Briggs charger automation up date (3.00 / 0) (#4)
by srnoth on Thu Dec 9th, 2004 at 12:31:46 PM MST
Very cool, simple idea. I like it. And at $3 who cares if it doesn't work. I'll definately try that.
Cheers,
Stephen.
Re: Briggs charger automation up date (3.00 / 0) (#5)
by ghurd on Fri Dec 10th, 2004 at 08:42:07 AM MST
Take the magnet off the back. There is a screw under it to get it open.
That took a while to find.
  92 Scoop users have viewed this posting.
· Also by Old F
