fiberglass moulds
By wpowokal, Section Homebrewed Electricity
Posted on Thu Feb 12th, 2004 at 04:59:03 AM MST
Advice needed
Can anyone guide me on making moulds of fiberglass blades, I would like to copy a commercial set before I cast them to the wind.
thanks Allan
fiberglass moulds | 5 comments (5 topical, 0 editorial)
Re: fiberglass moulds (none / 0) (#1)
by RatOmeter on Thu Feb 12th, 2004 at 07:43:04 AM MST
(User Info) http://www.rato.us
Have you worked with fiberglass before?
My father worked with fiberglass for many years, so I'm familiar with it but mostly from the sidelines.  My own experience is with a few little patch jobs, so if anyone notices glaring errors below, jump in and put me in back in line.
You'll need:
   1. Mould release.  Several varieties, generally you'll spray it on the part you'll be making a mould for.  Check with a local supplier for details.
   2. Fiberglass cloth.  Available in sheets, I think.  Definitely in rolls.
   3. Polyester resin or expoxy resin and the appropriate hardener (catalyst).  Ask your local supplier for details.
   4. (optional) Thick, honeycomb cardboard.  This can be used to build up thickness.
   4. Large scissors that your wife won't miss.
   5. Electomechanical tubing (EMT) to add rigidity to the mould.
   6. Paint brushes and, optionally roller brushes.
   7. Gloves and other appropriate clothing.
   8. A well ventilated work area.  The resin fumes can get nasty.
Construction:
   1. To make a parting line for the mould halves, you can cut long strips of thick cardboard, about 2 inches wide.  Wrap tape around the strips to cover it so that resin won't soak into it.  Tape the strip(s) along the edges of the part on the plane of the widest dimension.  I hope you can follow that; I wish I had pictures.
   2. Apply mould release on the side of the part you're starting on, including the parting line strip.  Don't miss any surfaces.  The mould release is to allow you to remove the mould from the part.
   3. Pre-cut some strips of fiberglass cloth.  Plan how/where you're going to apply them.  In making a mould, you don't need to worry about strength in the same way you would on a finished part.
   4. Cut one or more pieces of EMT either the full length of the part, or so two or more pieces can be overlapped to span the length.  This will be used later to give the mould the stiffness to keep its shape.
   5. Mix up resin with the correct amount of hardener.  I would use a metal coffee can or similar.  Don't mix up too much at a time.  If you're a first-timer, start with maybe a quart or less 'til you get the hang of it.  When the resin/hardener mix 'kicks', you could wind up with a warm can of useless, hardened resin.
   6. Brush on a generous coating of resin to the part where you're about to put some glass.  Just work on a smallish area at a time.
   7. Lay a strip of fiberglass onto the wet resin, working it in to fully wet it with resin.  Use a brush to add more resin on top, being sure to work out any air bubbles.
   8. Brush resin onto an area adjacent to the piece you've placed.  Apply the next strip of glass to it, but overlapping the first piece a fair amount.
   9. Continue in this fashion until (a) you run out of resin mixture or (b) your resin 'kicks' (hardens) or (c) you get tired of it.
  10. After covering the entire side of the piece and building up several layers, you can apply some strips of honeycomb cardboard.  Cover both sides of it with resin and stick it on.  Build up more layers of fiberglass atop this.
  11. When you've built it up enough, place the EMT along the length of the piece and wrap thoroughly wetted (with resin) glass strips around the EMT in several places.  At these places, lay more wetted strips over the EMT, adhereing it to the piece.  You don't want the EMT to move and you want the mould stiff
  12. When you're ready to repeat the process for the other half, remove the cardboard 'parting line' and apply masking tape along the lip of the finished parting line.
If you're new to this kind of thing, you might want to practice with some small parts first.  I know I would.
Re: fiberglass moulds (none / 0) (#2)
by Julio (j_andrade@cantv.net) on Thu Feb 12th, 2004 at 10:44:03 AM MST
try             http://www.itdg.org/
Mr. Pigott and other contributors have a fully documented article on the subject of blade castings.
Re: fiberglass moulds (none / 0) (#3)
by Gordy on Thu Feb 12th, 2004 at 11:58:00 AM MST
Also look back in the posts here 2-3 weeks ago. For allmost the identical question. pro's and con's were descused there, for molds, foam core, and wood.
Gordy
Re: fiberglass moulds (none / 0) (#4)
by knight4713 on Thu Feb 12th, 2004 at 04:42:07 PM MST
You can also do internet searches for Foundry Casting...
One method is to ...
  1. Cover one side with Clay and create a lip on one side.
  2. Put "dimples" in the clay. and cover the entire side with a release agent.
The dimples in the clay will help form markes on both sides of the form so they line up.
  1. Make your mold.  Put on a layer or resin then some cloth and more resin
  2. continue until the mold is as thick as you want it.
  3. take the part out after the mold has somewhat hardened.
  4. Remove the clay from the part and put the part back into the mold you just created.
  5. Cover the entire part and mold with a release agent.
  6. repeat 3-5 to make the second half of your mold.
Start with something small to get the hang of it...
It may also be helpful to make a frame to hold your mold.. That will give it some extra structural stability.
This has worked for me.  Although this was done for Plaster molds, but all you/we are doing is making a mold. It doesn't matter what the final product is made out of... not too much anyway...
Todd
Re: fiberglass moulds (none / 0) (#5)
by wpowokal on Sat Feb 14th, 2004 at 05:48:03 AM MST
Thanks for the advice people, clearly I have some reserch to do.
regards Allan
  98 Scoop users have viewed this posting.
· Also by wpowokal
