| left my frequency counter at work today, but monitored voltage at a nearby outlet in my machinery shed with a Fluke 73III multimeter. i adjusted the lister governor for a voltage output of 120 (varied from 118.9 to 120.2 during the 45 minutes). other that maybe a random well pump start or water heater coming on, i don't think the generator was very loaded. I measured the temperature at the exhaust elbow just out of the head with a cheap ir meter (rayotherm?) outside of elbow was 380F, the "muffler" supplied with the engine ran 360F. so i think a heat exchanger could pick some useful heat for water or heating applications. i figure the exhaust temp will pick up with an increase in load. i had to shut down the system after 45 minutes since i have no radiator to cool the engine at this point (i was using a temporary hopper cooling for this trial run) when i placed the house back on the grid, i noticed my voltmeter reading was 133.6 volts. the question i have for you fellows is: a. is 120 volts on my meter ok for household applications? b. is grid voltage high because, maybe i'm near the substation at the beginning of the local feed (the three phases actually split at the pole that has my transformer)?
note to self: never, never check the oil level while a lister is running. i got coated. Thanks fellows |
111 Scoop users have viewed this posting.
