| Hi , I will use this to track my design of a FSW inverter , I am nick naming it Godzilla :) this Intverter Will start at 40kw and be expanded to what ever you need
The output already can do 288kw , But will start with only enough DC/DC stepup to do
40kw
I thought about the multiable ways to do this and now I have up with a system that
would be easy to make , because I am using off the self MSW inverters as DC/DC
I take the output of a Cobra 2500w MSW run it into a Full Wave Bridge Rect. doubler
like you would find in a Standard PC smps this gives a +- 169volts ( 120 x 1.414)x2
( there are 16 of the MSW's paralleled)
I am using much better Caps then you will find in those power supplies and more of them. this supplies power to 4 300amp IGBT's 2 of these will put out 120v ac and other 2 will do the same but 180degree out . so that you get 240v ac just like your (maybe ex ) power company does , each one of these I call a FSW module and they will be 4 of them
of course there will be batteries connected to the MSW's
I have most of the parts here or on the way.
the 60hz Sine will come from a Crystal based circuit
found here
http://www.fairchildsemi.com/an/AN/AN-42025.pdf
it works I breadboarded it tonite , it makes a perfect sine wave right at 60hz , I do not have a freq counnter , but on my scope it is dam close , I have layed out a board based on this and will be making it this weekend
it gets its +5 , -5 from a LM555 running as a neg volts converter .
this will drive a National LM4651 class D chip or I will also be testing a PWM based on
LM555/LM339. The IGBT drivers will be IR2110.
I will post Schmatics and Board layouts as I make sure they are tested
well that is it for tonite |
151 Scoop users have viewed this posting.
