SLIP RINGS
By johnjach, Section Homebrewed Electricity
Posted on Wed Feb 04, 2004 at 03:52:58 PM MST
Where can I buy electric slip rings?
I want to make genny using an Ametek motor and some commercially made blades.  I would like to put this on a standard 1-1/2" black iron pipe as a "tower."  I know some of you say I can use ordinary welding wire and forget about using slip rings but if I do want to go this route, where can I get some reasonably priced?
SLIP RINGS | 3 comments (3 topical)
Re: SLIP RINGS (none / 0) (#1)
by zubbly on Wed Feb 04, 2004 at 05:38:38 PM MST
hell johnjach.
     you could try your local motor rewind shop. often they salvage slip-ring assemblys from wound rotor motors, or you could try a small portable generator shop for new or salvaged slip rings.
good luck-zubbly
Re: SLIP RINGS (none / 0) (#2)
by Homebrewed12vdc on Wed Feb 04, 2004 at 07:12:45 PM MST
I wouldnt bother with the slip rings, you well lose a sigificant amount of power through them and when you are only dealing with a small amount of power to be had from a maeteck motor you cant afford to lose any. Cable twist is not a issue, its just a myth.
Re: SLIP RINGS (none / 0) (#3)
by DanB on Thu Feb 05, 2004 at 09:28:24 AM MST
If its like most ametek motors Ive seen, you're probably looking at a machine with about a 4' diameter prop, and maximum output of around 100 watts (a bit more on occasion) - so welding cable would be overkill.  You would probably do fine with a 10 or 12 gage extension cord down the tower.
  77 Scoop users have viewed this posting.
· Also by johnjach
