Solar water pump
By Frank Lussier, Section Homebrewed Electricity
Posted on Wed Mar 10, 2004 at 06:27:51 PM MST
Need  some advise on deep well solar pump
Hi guys
I need to change my deep well pump, right now my pump is 220v 1/2hp set to 75psi and I need to change to solar. I saw on the net some solar pump for $895usd but I need some advise, which one should I buy, I need to change the pump and a few things before I go off grid.
Any advise?
Frank
Solar water pump | 7 comments (7 topical)
Re: Solar water pump (none / 0) (#1)
by Gary D on Thu Mar 11, 2004 at 07:39:43 AM MST
Hi Frank, there are several ways to go here. The easiest thing I can think of is to pump with your existing pump with a generator into a cistern for storage. Then you can use a low voltage pump for as needed water. If you are going to top off batteries daily, this is the way I would go.
Otherwise,depending on static level of your well ( how low below ground level the water is if not pumped for several hours), recharge rate of well ( how fast the water level comes back to the static level), and your current wire size, you could go with an inverter and 110 volt pump. Understand that downsizing to 110 volts means doubling the wire resistance. If the pump installer had a little foresight ( thinking you might upgrade to a 3/4 or 1 hp pump) and has a decent gauge wire to your existing pump, possibly you could use a 110 volt 1/2 hp deep well pump ( otherwise means shortening pipe and pump)
My best advise is to give a well driller a call ( or a pump installer) and explain what you are planning and ask them your options are.  Hope that possibly some of this helps  Gary D.
Re: Solar water pump (none / 0) (#2)
by John D on Thu Mar 11, 2004 at 10:00:53 AM MST
Heh Frank,   Have no idea of your requirements but check out www.capsolar.com   &   www.surflo.com  These guys all have solar stuff and will have a better price than $900 USD.
Good Luck
John D
Re: Solar water pump (none / 0) (#3)
by Demetri on Thu Mar 11, 2004 at 04:07:38 PM MST
Try this (http://www.donrowe.com/inverters/aims_3000_240V.html). I have two, one powers my 3/4 hp well pump and another powers the 2 1/2 hp motors in my septic system. My well pump can draw over 70 amps @ 12v, and I don't know how much 12vdc power you have available, but this is an option.
Demetri
Uncommon sense required.
Re: Solar water pump (none / 0) (#4)
by Gary D on Thu Mar 11, 2004 at 07:54:07 PM MST
Great link  Demetri- first inverter exclusevly for 220 that I've seen! Was thinking the only thing to do was stack 2 110's. Sure beats the holding tank option.   Gary D.
Re: Solar water pump (none / 0) (#5)
by TomW on Fri Mar 12, 2004 at 04:45:30 AM MST
Demetri;
On that inverter, does it have some method of remote switching to power it up only as needed?
Re: Solar water pump (none / 0) (#6)
by Gary D on Fri Mar 12, 2004 at 10:37:39 AM MST
Hi Tom, didn't see that optoin on that model, but it only pulls  .6 amps no load. thinking here is that's @ 12 volts but could be wrong. Sorry I answered for Demetri, but saw remotes for a bunch of there other inverters. Possibly interchangeable?  Have a Good day Gary D
Re: Solar water pump (none / 0) (#7)
by Demetri on Fri Mar 12, 2004 at 02:10:50 PM MST
TomW: I don't think so, each inverter seems to draw about half an amp all the time.
Demetri
  63 Scoop users have viewed this posting.
· Also by Frank Lussier
