| Im testing a coil for a dual rotor clone 12 magnets on each rotor. Im only using one rotor with 12 magnets for the test as im not ready for the second rotor. i chucked up the rotor in my lathe and set the rpm for 266. my coil is 25 turns on number 16 wire taped right hard up against my tool block that is about 2 inches thick steel. im getting .57 dc volts on the plus and minus side of the bridge rectifier. question 1 will this double when i put the other rotor on. question 2. im showing 12.5ma amps with my meter in the 200ma scale out of the bridge rectifier. I wont read in the 10 amp scale yet. is that like a 1/8 of an amp??. will this go up with the other rotor on it. If i find some 18 gauge wire will these both of these go up or just the voltage. I dont have much wire to burn up for a lot of tests. Any suggestions. Thanks JB |
88 Scoop users have viewed this posting.
