| I apologize in advance for the length of this posting, but you will be helping me a great deal in advising me on my ordeal.
I currently have a Prestolite 50 amp alternator, with an internal regulator, on a Westerbeke 30b (27hp) marine engine, which apparently delivers a maximum of approx. 40 amps, per the Westerbeke dealer. There is nothing "marine-like" about this alternator from an electrical perspective -- it is from a practical standpoint an automotive alternator set-up.
My dilema began when I started my quest to increase the size of my battery bank (amp/hr) to aprox 220 amp hours. These are 2 deep cycle golf cart batteries connected in series to attain a 12V output. The problem is my alternator, I've been warned that given the size of the increased battery bank that my alternator will not be able to keep up with the demand of the batteries if drained enough, and will not recharge quickly enough. The dealer and others have told me that I should definitely replace the alternator. However, this has proven to be difficult (from a sizing limitation perspective) and expensive, since I would have to also modify the brackets.
My question therefore is, can I have an auto shop increase the amps output without increasing the dimensions (especially the depth) of the existing alternator? Would they also be able to remove the IR and provide me with the ability to use an external regulator for more efficient charging (should I do this?)? If not, should I be looking to also modify the existing regulator? Please help !!!
Apologies once again for the lengthy posting and thanks for sharing your much appreciated and much needed expertise
Rgds,
-Chuck |
87 Scoop users have viewed this posting.
