and today i will finish them up. I have to drill and tap lowering bolts and then sandblast it. then comes the fun part of gluing my magnets on. These rotors are 14" in diameter and are 1/2 steel. They are heavy,.. but its what i had lying around. I doubt I will see any flux leakage on the backside of the rotors by using 1/2" steel. This machine will get the wedge shaped neos DanB used in his 14' machine. Im thinking of going a bit bigger on the prop for this one though.. possibly 16'. This machine will use a 24V stator. The spindle I have clamped in the vise might end up being the one I use for the machine because I too have run out of volvo parts hehe.
To the right in one of the pics you can see the hub I made up to allow me to spin these on the lathe and balance them. I basically transfered the lug pattern and bolt them on. If you dont have a shop to cut them for you and you have to end up doing it yourself (like I did) I found it much easier to cut them out with a torch and stack them on top of each other and tack weld them together. If you do this in the beginning,... there is no reason why they wont come out identical in the end. The welds can always be cut off in the lathe when you make the final outer edge cut. Im having a blast!! -RoyR
30 Scoop users have viewed this posting.
