High voltage transistors
By RobC, Section Homebrewed Electricity
Posted on Sat Mar 20, 2004 at 07:41:53 PM MST
Can't find specs.
I found some transistors in some kind of inverter and I can't find any info on them.
They are made by toshiba the number on the unit is MJ300J1US1. The only info I found
was 600V 300A but thats it. They appear to be 2 transistors in one case. Any ideas?
Thanks RobC
High voltage transistors | 5 comments (5 topical)
Re: High voltage transistors (none / 0) (#1)
by kell on Sat Mar 20, 2004 at 08:24:07 PM MST
Toshiba has an IGBT 600V 300A with a just slightly different number.  Maybe yours was a previous generation.
http://www.toshiba.com/taec/cgi-bin/display.cgi?table=Category&CategoryID=7017
Re: High voltage transistors (none / 0) (#2)
by drdongle on Sun Mar 21, 2004 at 08:42:35 AM MST
I have had good sucess with putting the part number in Google. There are several Russian sites that seem to have info no on else has.
Dr.D
Carpe Vigor, Dr.D
Re: High voltage transistors (none / 0) (#3)
by RatOmeter on Sun Mar 21, 2004 at 10:55:42 AM MST
I've noticed that too.  But I also get frustrated by the huge number of results that turn up that have no info, just lists and lists of part numbers of NOS parts for sale.
-RatOmeter
Re: High voltage transistors (none / 0) (#4)
by TomW on Sun Mar 21, 2004 at 11:51:07 AM MST
RatOmeter;
Try some boolean in your searches if you get too many "for sale" sites use a [-sale] in there. With the right combinations you might be amazed at how fine you can prune the results.
Re: High voltage transistors (none / 0) (#5)
by RobC on Sun Mar 21, 2004 at 10:08:07 PM MST
Thanks for the help guys. RobC
  66 Scoop users have viewed this posting.
· Also by RobC
