| picked up another link in my cogenerator project
230/460 volt, 3 phase 1140 rpm motor
going to connect it to the front of the thermoking unit (isuzu) diesel engine via a driveshaft w/ujoints.
low idle govenor setting is 1300 rpm with the engine, accounting for some droop in rpm i should be close to the generating point of this motor.
not sure how much mf. in capacitors i need to convert the motor into an induction generator, source i have lists up to 10hp at 1740 rpm. the source also says to increase mf. for lower rpm motors, but doesnt say by how much. also doesnt tell me much about hp ratings above 10 hp.
any info would be appreciated
also my electronics training is rusty, need to know if the following is correct
- 2- 10 mf capacitors in parallel = 20 mf. ?
- 2- 10 mf in series = 5 mf?
- can 2- 100 volt rated caps placed in series handle 200 volts?
i just cant seem to remember the rules relating to series/ parallel operation of capacitors.
anyone??
bob g |
136 Scoop users have viewed this posting.
