Electric dryer????
By halfcrazy, Section Remote Living
Posted on Fri Apr 16th, 2004 at 06:28:11 PM MST
This may be a dumb question but?
this may be a dumb question but i have a free electric clothes dryer. my question is i have a wheelhouse 5800 watt generator that has like a 8500 watt surge capacity. will the dryer run off this generator? we are hoping to use it when the weather is bad for days on end other wise we hang the clothes out. this is a temp set up till i can afford my gas dryer. Thanks for the feedback. Also what does everyone think of the staber washer?
Electric dryer???? | 10 comments (10 topical, 0 editorial)
Re: Electric dryer???? (3.00 / 0) (#10)
by keleyu on Tue May 17th, 2005 at 08:06:55 AM MST
that's mostly easy
My homepage: gadgetsflashgames
Re: Electric dryer???? (none / 0) (#1)
by drdongle (Dr.Dongle1@juno.com) on Fri Apr 16th, 2004 at 06:53:13 PM MST
You need to check the specs on the dryer befor this question can be answered.
Dr.D
Carpe Vigor, Dr.D
Re: Electric dryer???? (none / 0) (#2)
by Norm (peppysue@suite224.net) on Fri Apr 16th, 2004 at 07:15:00 PM MST
  Okay this may sound like a dumb answer but if you have the dryer like out in a shed where you could run the dryer on air only. Run the exhaust from the generator double or triple loop behind the dryer where the air intake for the dryer is located, so the dryer will suck up the exhaust heat from the engine. This way you'll just need electricity to turn the drum and the blower.
          ( :>) Norm.
( :>) Norm
Re: Electric dryer???? (none / 0) (#3)
by halfcrazy on Fri Apr 16th, 2004 at 07:55:05 PM MST
Norm hadnt thought of that but that would be a cool idea. i think my generator will run it on medium heat and i could use the generator exhaust to preheat it and leave the element on medium
Re: Electric dryer???? (none / 0) (#4)
by Parameter on Fri Apr 16th, 2004 at 08:14:26 PM MST
(User Info) http://pages.infinit.net/gebet
Also, if you are up to ducting the air input, you could make a small airtight can to heat over a propane oven or home made burner. I made a burner with bbq parts. But of course, i never said it was totally safe. Be carefull.
Or you could just put a small wood over in the shed or ouside with a roof and use the heat exchanger and you'd be set for nice hot air and very little electric power need. Me I'll do that at my small shack to heat the place.
Para
medium heat (none / 0) (#6)
by Norm (peppysue@suite224.net) on Sat Apr 17th, 2004 at 06:23:09 AM MST
  Ok but the electric clothes dryer don't really know how to give medium power load on 220 it's going to turn on those heating elements full power until you've got medium heat or whatever. Now if you just run it on 110 volts. On ours if one fuse blows ...the dryer doesn't run....if the other side blows ....runs but doesn't heat much if at all.....110 volts in other words.
   Now if management(my better half) would only let me fix some ductwork so the dryer could suck down hot air from the attic on hot sunny days and I could replace that 110 volt dryer motor with a 12 volt motor........independant of the 220 volt heating elements .
                  ( :>) Norm.
( :>) Norm
Re: Electric dryer???? (none / 0) (#7)
by BrianK on Sat Apr 17th, 2004 at 07:30:13 AM MST
Norm your idea sounds ok,but it better be a very well sealed pipe or you might get cloths that have a nice exaust smell   yuck :(
Re: Electric dryer???? (none / 0) (#5)
by old55olds on Fri Apr 16th, 2004 at 09:09:55 PM MST
Just remember that drier lint is EXTREMELY inflamable
Re: Electric dryer???? (none / 0) (#8)
by nothing to lose (nothingtolose175 at yahoo.com) on Sun Apr 18th, 2004 at 01:22:09 AM MST
The heating element is the power hog on an electric dryer. As others have stated many options to do away with it :)
My wife was using one durring the winter and bad weather, nice warm sunny days we hang out also when we can. Sometimes with the humidity though it seems like the clothes actually get wetter around here!
Anyway, when the heating element breaks in our dryer (as it has several times) the dryer tumbles normally but of course no heat. I just got a really nice GAS dryer for about $10 at a yard sale. Was so cheap because it is set up for natural gas and all  we have available in this area is propane and nobody wanted to mess with changing it over. I think the gas companies do it free though so go figure.
Anyway again, with either dryer they will tumble fine without heat, and the duct for air intake is easy to get to really. The gas one points to the front so I have a little box I have to take off and turn to the rear, on this one it was easy. Thats where the burner was. On the electric one there was a nice little duct going up the back that also has the heat element in it. Take the wires off the element and insulate them well so they can't short out, then just run a duct to the bottom of that duct.
For a heat source anything will work that heats air as it passes by :)
Build a solar collecter box for those hot sunny days? Build a small trash burner/ wood burner. Got garbage? Take out the trash to burn when drying clothes, use the heat produced to heat a seperate chamber of fresh clean air. As mentioned you could also use the heat from the gennie exhaust if it's running, but drying on 110v you may not need it then.
Another thought if you can, build one of those producer gas plants to run a gennie on, then when you burn wood for fuel for the gennie you can heat water for washing and hot air for drying too, and still run the gennie on the cooled gas. Get all three in one shot :)
In all dyrers I have looked at myself, the blower runs anytime the drum is tumbling. The heater makes no difference. As a matter of fact I think they are almost all built onto the motor shaft that turns the drum, so if the motor runs the air moves. No need to worry about it only working like when heat is present as a friend thought, they move air always. So however you do it, all you need is 110v for the motor and timer normally and some heat from any source, plus a small duct pipe/hose to connect to the heat source.
The only things I would even worry about is if you use some sort of fire to heat the air make sure it can't get too hot! You want to heat the clothes, not bake at 550 for an hour or till melted :(
As mentioned by another, dyrer lint is flamable, but that is on the exhaust side not intake, and you won't be ducting that to the heat source.
An you don't want smoke or fumes, but that's mostly easy, just don't lay the open end of the pipe into the fire :)
We burn our trash here and I am building a producer gas plant, so I am planning to use the heat from those too sources for alot of things.
I would compost the trash, but I get alot of it that's not well composted so I incenerate it (burn baby burn) cleanly. Darn packing peanuts!
Re: Electric dryer???? (none / 0) (#9)
by BSparky on Sun Apr 18th, 2004 at 10:05:38 AM MST
If memory servers me right dryers fused 30amps 240volts will use less current maybe 25 amps. The ones I've taken apart had couple elements, I'd disconnect one. If anything won't overwork your genset.
What I did with my old electric dryer was plumb it off my wood burning furnace. Seal up the inlet vents, holes etc. cut a six inch diameter hole init. Put a starter duct collar on, then pipe it to the burner's hot air plenum. Only drawback the furnace is design around a closed filtered force air system had to put a damper inline of ductwork to prevent hot air blowing through the dryer when not in use. Wife called me cheap I've called it practicable. She slowly coming around.:>)
Next goal is to make something like nothing to lose's a solar flat plate collector for when the solar clothes line isn't fast enough.
Timber
  109 Scoop users have viewed this posting.
· Also by halfcrazy
