I was wondering if anyone here remembers those and more importantly has any experience with this sort of unit. My Ametek motor needs to be driven at or over 1700 rpm to get descent charging for my 48 volt system. On those systems the prop was mounted to the axle much as the dual rotor style everyone here seems to be building. But on their unit the rear end differential was retained , the other axle welded to a fix position at the tail and the generator attached to the drive shaft input. This resulted in a speed up of about 7:1. I guess the down side was oil seals,... and weight in the air. I don't want to use belts for my speed increaser (I just don't like belts). With 7:1 ratio I only should need 250 to 350 RPMs, which sounds more reasonable.
Anyone out there seen or used anything like this? |
109 Scoop users have viewed this posting.
