New Multi-Rotor Turbine
By DougSelsam, Section Diaries
Posted on Tue Apr 6th, 2004 at 01:27:24 AM MST
Yep it gets like 4000 watts at 28 mph
So anyways, yeah it makes like 1000 watts at 16 mph, 4000 watts at 28 mph, peaks of 5000 watts so far in the furled position.  Funded by the California Energy Commission.
Doug Selsam
http://www.selsam.com
New Multi-Rotor Turbine | 3 comments (3 topical, 0 editorial)
Re: New Multi-Rotor Turbine (none / 0) (#1)
by wiredup on Tue Apr 6th, 2004 at 08:45:55 PM MST
HI doug nice genny!!! have looked at your website almost a year ago,or so.i can tell you put some thought and alot of work into your machine.would you share with us some spec.on your genarator and rpms. thanks staples....
Re: New Multi-Rotor Turbine (none / 0) (#2)
by DougSelsam (Doug @ Selsam.com) on Sat Apr 10th, 2004 at 11:58:35 PM MST
(User Info) http://www.Selsam.com
I'm guessing 800 - 1000 rpm peaks.
They are two 3-phase alternators with 28 poles and 84 slots inside the same case.
Each rectified externally and separately.
Douglas Selsam Selsam Innovations 2600 Porter Ave. Unit B Fullerton, CA 92833 Doug@Selsam.com http://www.selsam.com 714-992-5594
Re: New Multi-Rotor Turbine (none / 0) (#3)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Sun Apr 11th, 2004 at 01:13:32 PM MST
A really interesting machine.
How is the 'rod', where the wind turbines
are, supported so that it doesn't bend?
  148 Scoop users have viewed this posting.
· http://www.selsam.com
· DougSelsam's Diary
