| OK, I've succeeded in getting myself into a bit of a technical bind and thought I'd troll for some advice.
I just purchased a really sweet old wind machine. 3kw and 140 volts DC. However, my battery system is 24VDC and I'm off the grid. I'd really like to use this baby but I'm going to need to modify the output to do so or I could fry the windings. So far I have come up with a few concepts.
- Get a really big MPPT controller and try to rig a dump load that kicks in somehow. I'm not sure such a thing exists that would work for a wind machine. Outback power is working on it, but it's a low priority they say. This would need to handle over 150 amps of output amps (at 24v).
- Rewind the generator to put out a lower voltage. (big fat wires) It seems a shame, but it might be the easiest way to go.
- Run the wind generator into a couple "Windy Boy" inverters that pick up the "grid" from my Prosine 2500 inverter and let them charge the battery via the Prosine's built in battery charger. This sounds really convoluted and I'm not sure it'll work. But sometimes it seems logical. Other times it's just too circular.
So, any other schemes that might work ? I know I'll have to get a big dump load in any case. I'm thinking hot tub. ;) I don't know of a dump load controller that'll handle that kind of power either, so maybe dumping at the 140v DC level would be more prudent.
Thinking out loud...
Chuck |
146 Scoop users have viewed this posting.
