Solar Panels
By franknbuger, Section Homebrewed Electricity
Posted on Mon May 17th, 2004 at 05:49:13 PM MST
How much sun
  Hello. I built several alts, but there dont be no wind.I am thinking solar might be better in my locale.There is limited space where I am at,and my shack is under some large shade trees.Could someone guess-ta-mate or know, do you need full sun shining on the panels, or does the light from the sun do the trick.If there is only light shinning what can I expect from them,percentage wise. Please Advise....
                                                  Frankenbuger
Solar Panels | 6 comments (6 topical, 0 editorial)
Re: Solar Panels (none / 0) (#1)
by TomW on Mon May 17th, 2004 at 06:14:46 PM MST
frank;
Well, unless you have an acre of panels don't expect much without direct sun for a substantial part of every day. I have 300 watts of panels that actually put out a steady 18 amps in full sun. In the shade or with overcast skies its maybe 1 or 2 amps at best. Sticking them up on poles can help get more direct sun and a tracker is well worth the effort also.
Re: Solar Panels (none / 0) (#2)
by franknbuger on Mon May 17th, 2004 at 07:18:01 PM MST
 Thanks  Thats what I was suspecting.Well let me see now: No Sun--No wind sooooo!
 Maybe I can steal a back-hoe & 16 miles of 00 copper cable, and hook up to the grid some where else.No one will find out I got an honest face.
Re: Solar Panels (none / 0) (#3)
by RobD on Mon May 17th, 2004 at 07:36:28 PM MST
You might have wind you may have to go quite high to get it. Got any hydro, that's the best?
RobD
Re: Solar Panels (none / 0) (#4)
by franknbuger on Mon May 17th, 2004 at 07:53:10 PM MST
   Yes,we aint got no hydro,the river just sets there like its asleep.Cant build a tower, restrictions dont you see.Guess its the B&S alt or nothing.But it cost $1.27 to run the engine 4 hrs.And it cost .25 to buy from the same grid,that was last week.At this rate Ill go broke,playing only two games of FreeCell,using battery power.Where theres a will theres a way.   Frankenbuger
Re: Solar Panels (none / 0) (#6)
by Norm (peppysue@suite224.net) on Mon May 17th, 2004 at 09:57:57 PM MST
  Frankenberger! Believe it or not You can shut off the computer and play free cell with a regular deck of cards You can have a couple of VAWT's double helix... pump water...hydro power ...electricity when needed lift a large weight released thru a generator, pedal power to augment the VAWT's get an old diesel truck and run it on biofuel burn old crankcase oil smokelessly and heat water for running a hot air engine as in
http://www.rotarystirlingengines.com/sexbaloon.htmon a larger scale than this like 15 gallon drums and innertubes instead of ballons!
   If you have winters where you live you can build an ice house make ice blocks in the winter and never need a refrigerator again!
   Build wind gennys and sell them to people that do have wind. The possibilities are endless...just use your imagination!
             Havin Fun Just Thinkin' of All This Stuff!        ( :>) Norm.
( :>) Norm
Re: Solar Panels (none / 0) (#5)
by pexring on Mon May 17th, 2004 at 08:34:43 PM MST
If it's do or die, maybe have to chop down the tree and let the sun in?  I suppose the wind genny would have to be higher than the trees to also get any breeze.
Mark
  71 Scoop users have viewed this posting.
· Also by franknbuger
