| Tip:
I have seem many postings, people asking...How do I attach a Tape Drive Motor shaft to a Prop? Most Ametek motors have a 5/8" shaft. Look on the Internet for a 5/8" Shaft Adapter or goto Lee Valley and order their Adapter... http://www.leevalley.com/
wood/page.asp?SID=&ccurrency=1&page=41743&category=1,43072,4593
9 It slips onto the shaft and gives you a 1/2" threaded end with lock washers and nut. Two set screws apply pressure to the shaft to keep everything in place. Then just attach your props to the 1/2" thread and your set.
Now how do you attach the motor to a frame. Oh sure you could build something, but save your self some time. Goto Lee Valley and get their Motor Mount... http://www.leevalley.com/
wood/page.asp?SID=&ccurrency=1&page=30047&category=1,240,41067 This item allows you to mount the motor to a piece of plywood.
Hope this helps.
Rob
"Objects are closer then they appear" |
46 Scoop users have viewed this posting.
