DynOhub
By Jon Miller, Section Homebrewed Electricity
Posted on Sat May 29, 2004 at 03:00:38 AM MST
Has any body used one?
I was looking down the road towards my neighbours and saw a really old bike had been thrown away in a ditch.  i had a look at the bike and saw it had a dynohub on it.  Now I've looked up about them on the web and found out that their rated a 3W 6V @ 60rpm.  I've managed 10v from spinning by hand.  Has anybody else every used a dynohub for a wind gennie?
The pdf file is of the layout of the dynOhub.
http://www.otherpower.com/images/scimages/576/sagh6.pdf
Jonathan Miller
DynOhub | 6 comments (6 topical)
Re: DynOhub (3.00 / 0) (#6)
by gotwind on Sat Feb 04, 2006 at 11:12:47 AM MST
See my new website - it's all based upon Sturmey Archers excellent Dynohub and how they can be used as wind generators. www.gotwind.org
Ben
Re: DynOhub (none / 0) (#1)
by Norm on Sat May 29, 2004 at 06:01:27 AM MST
    Why can't I be that lucky?
             ( :>) Norm.
( :>) Norm
Re: DynOhub (none / 0) (#2)
by mkseps on Sat May 29, 2004 at 09:09:36 AM MST
About 40 years ago, the US Weather Service took two of these devices and mechanically hooked them in parallel for use in remote areas to record weather patterns.  These were very reliable alternators that were designed and built in England.  Even today, you will find that the engineering is quite remarkable and those design details could be scaled up for greater output.
Gene
Re: DynOhub (none / 0) (#3)
by Zero on Sat May 29, 2004 at 05:35:39 PM MST
Hi, I've built small wind chargers and picopico hydro's from old Dyno hubs, they're almost indistructable but their main downside is that over a certain rpm they dont generate any more power, this is suposedly intentional in the design so when you go zooming down a steep hill on your bike you dont blow the bulbs.
Have fun.
Z
Re: DynOhub (none / 0) (#4)
by mkseps on Sat May 29, 2004 at 06:13:01 PM MST
You are correct in observing the self regulating characteristic of this alternator.  What the designers did was to use lamination materials that saturate in the desired power range.  Thus, beyond a cetain point, additional rpm's have little additional output.  So, they didn't need any dump load.  This is a superior design system.
Re: DynOhub (none / 0) (#5)
by jbenz0 on Mon May 31, 2004 at 10:11:20 AM MST
http://www.c-realevents.demon.co.uk/steppers/stepmotor.htm
-one of my very favorite sites.
http://www.motherearthnews.com/index.php?page=arc&id=5083
  78 Scoop users have viewed this posting.
· http://www .otherpower.com/images/scimages/576/sagh6.pdf
· Also by Jon Miller
