Solar powered fan
By tawa, Section Homebrewed Electricity
Posted on Sat May 29, 2004 at 06:05:28 AM MST
Solar powered fan, how to
I'd like to make a solar powered fan. At allelectronics.com there is a 6"x6" solar panel which outputs 9vdc. There is also a 5vdc fan. Do I need anything else besides a switch and resistor (to get the solar output down to 5vdc)?
9v sounds like an awful lot of power for a 6x6" panel. Could that be a typo?
Thanks guys! You are a big help!
Solar powered fan | 3 comments (3 topical)
Re: Solar powered fan (none / 0) (#1)
by Norm on Sat May 29, 2004 at 06:18:27 AM MST
  It's probably open voltage when you put a load on it (the motor) might drop drastically the motor might be even underpowered.
    Just my opinion don't quote me.
               ( :>) Norm.
( :>) Norm
Re: Solar powered fan (none / 0) (#2)
by jimu on Sat May 29, 2004 at 07:31:57 AM MST
Just for fun , I purchased one of those 12 volt dashboard solar panel battery maintainers , from Harbor Freight Tools for 9.99. It outputs a bit less then the stated amps, but was able get about 180 ma from it. I then hooked it to an old PC power supply fan I had in the junque box, and it ran fine directly off of sunlight.
More of a novelty than having it do anything useful. But it will charge up small SLA's and power my boombox on the patio for the evening :-)
JimU
Re: Solar powered fan (none / 0) (#3)
by Chagrin on Sun May 30, 2004 at 04:19:25 AM MST
To anyone interested, you can use code "44768-2NWB" to get it at the $9.99 price.
  71 Scoop users have viewed this posting.
· Also by tawa
